drjeeva wrote:Hi guys, my blue coops shocks hev given up the ghost. What is the most suitable replacement ( I need the ride comfort of the Fiat's original shocks ) for the coop? From what I read on the forum you guys feel the Bilstein B6 is the closest. Any idea abt the price for a full set?
Thanks
kgpa wrote:fabricate the shocks.....custom made for less than $2k
pistole wrote:
- who is doing this ?
drjeeva wrote:Ok looks like it's the monroe then. Anyone know the correct part number for monroe reflex shocks for the fiat coop 20vt? I gotta get the order correct since I'll hev to get my mechanic here to order a set for me.
Yeah, thought I wuz selling too
gtfan wrote:I hope titan solved the top mount crack issue.
It could be an old issue but there have been cases on some of the ex-IA rides. Alfa and Fiat too.
Would you say your front's are hi-lo adjustables and the rear is similar to standard setup?
Salsero wrote:I just installed a complete Titan suspension set-up See an earlier post ("Senget sebelah" or something like that):
a. 4 x shocks (front have collar for height adjustment)
b. 2 x front springs
c. 2 x front shock mounts.
Front height is adjustable using the collar around the shocks. Rear height requires some "mickey mousing" with the OEM springs (see below). Camber adjustable at bottom end of shock.
Total cost: RM 3k
What can I say? I am absolutely thrilled!
kgpa wrote:Salsero wrote:I just installed a complete Titan suspension set-up See an earlier post ("Senget sebelah" or something like that):
Total cost: RM 3k
I had a ride in his car and the overall balance is spot-on, simply brilliant and definitely much much better than just substituting Bilstein B6 over the "stock" boge. It feels so sharp, firm but yet able to soak up most of the road undulation. It does not bounce all over or judder at all.
This is perhaps due to the stiffer springs, as TITAN recommends a stiffer set-up to compensate for the heavy "front-end" of the coupe (it has 65%;35% weight distribution.
I am definitely trying to replicate this set-up for my coupe with TOP perfect, but by using the stock springs....let see how it goes
regards
TOP PERFECT
2770B Kampung Baru Sungai Buloh 47000 Sungai Buloh, Sungai Buloh 47000, Selangor
p: 603-61571370
Website - None Supplied
Email - None Supplied
DeaDLocK wrote:Guys, are the standard shocks for the coop supposed to be quite firm?
You know when going over those raised yellow lines on highways (approaching toll booth etc), on normal cars I can just drive over with minimal bumps but in the coop I actually have to slow down as the lines get closer to each other cos it feels like driving over canyons - I would call it quite crashy.
gtfan wrote:DeaDLocK wrote:Guys, are the standard shocks for the coop supposed to be quite firm?
Stock is already crashy over those yellow stripes. Fit koni and eibach, the coupe will feel like the dasboard going to drop off.
i alwys something is weird with my shocks...
ahhl wrote:
TOP PERFECT
p: 603-61571370
jonboy83 wrote:my shocks are gone...the B6 lasted me exactly 2 years.
now sourcing for alternative and was looking for Konis but quoted 2.7k per set!
is this the price? i always thought Konis are below 2k for the coupe.
will use monroe to save some dough as i need to change my clutch as well.
sad sad....
