jonboy83 wrote:my shocks are gone...the B6 lasted me exactly 2 years.
now sourcing for alternative and was looking for Konis but quoted 2.7k per set!
is this the price? i always thought Konis are below 2k for the coupe.
will use monroe to save some dough as i need to change my clutch as well.
sad sad....
kgpa wrote:jonboy83 wrote:my shocks are gone...the B6 lasted me exactly 2 years.
sad sad....
Hi Jonboy....can I have your depleted and worn - off Bilstein Shocks, please![]()
I can collect...thanks
gtfan wrote:jonboy83 wrote:my shocks are gone...the B6 lasted me exactly 2 years.
sad sad....
Did you chk with singapore.....? It should be below rm2k
pistole wrote:- car is not supposed to sag.
- check your front driver's side suspension turret , some have experienced cracking with the use of hard shocks.
raitag wrote:Below 2k konis are from SG...
no la farmer... that's not the issue... my car doesn't sag one side...
tazztham wrote:i also like to upgrade my rear weekend shock to be stiffer. do you think even stock std coupe will be stiffer than my std weekend? i m also looking at monroe std or monroe reflex. according to catalog, they don't make monroe reflex for coupe.
based on catalog monroe reflex has better tech but no actual part for coupe. but can use 145/146/155 parts right?
wondering...
