Project 300.
Postby UlysseNuovo » Sat Jun 05, 2010 7:46 am
Hahaha, suppose to post some pictures awhile ago but did not find the time to gather all of it.
Well, now here we go....
(106.83 KiB) Downloaded 327 times
How many folds?
(91.95 KiB) Downloaded 327 times
(102.16 KiB) Downloaded 327 times
The intercooler is just a little lower. It scrape on bumps when coming down from a slope.
(126.53 KiB) Downloaded 327 times
The 'snail' :)
(98.03 KiB) Downloaded 327 times
3" piping, the middle and rear still on 2.5".
(102.46 KiB) Downloaded 327 times
Fixing the thermal wrap.
(119.33 KiB) Downloaded 327 times
It doesn't matter if a cat is black or white, so long as it catches mice.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby UlysseNuovo » Sat Jun 05, 2010 3:31 pm
As I posted earlier, I decided to go with an external wastegate, so in she went again into torque gear.
(63.56 KiB) Downloaded 306 times
(69.45 KiB) Downloaded 306 times
(67.21 KiB) Downloaded 306 times
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby UlysseNuovo » Sat Jun 05, 2010 10:40 pm
Redd wrote:wah Tial wastegate. screamer or no screamer? ;)
cant wait to see the dyno numbers on this monster!
redd
As you requested, dyno was done when I am still on gtec1, now I am on the gtec1 higher fuelling since I do not have enough fuel going in as shown on the dyno chart.
(82.9 KiB) Downloaded 281 times
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby Redd » Sat Jun 05, 2010 11:03 pm
bro why no torque and boost curves wan?
redd
Electricity comes from electrons; morality comes from morons.
Redd
Postby UlysseNuovo » Sun Jun 06, 2010 1:38 am
Ada la, the faint red line. Scan quality not that good.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby UlysseNuovo » Sun Jun 06, 2010 1:41 am
At about 3800 rpm I am boosting 1.05 - 1.1 bar.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby desin » Sun Jun 06, 2010 2:50 pm
few suggestion, which is worth to consider :)
I'm running on 'hose quick-tap nipple', coz last time i was on SMIC, and i can't manage to find the 'elephant' hose, but now i got one used ready :) I'm going do to this :)
(123.97 KiB) Downloaded 231 times
(173.68 KiB) Downloaded 231 times
desin
IA Northern Rep
IA Northern Rep
Postby UlysseNuovo » Sun Jun 06, 2010 3:44 pm
Thank you for your suggestions, at the moment the only part that scrape the bump is the black metal bar bolt when I am coming out of my condo.
So far so good.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby FlameON » Mon Jun 07, 2010 4:20 am
Dude, Looking sweet. will need to sit down and get tips from you lah now
To Infinity & Beyond
FlameON
Postby UlysseNuovo » Fri Jun 11, 2010 3:51 am
Bro, I got your p.m. I will let you know when I get back from touring.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby UlysseNuovo » Wed Jun 23, 2010 5:30 pm
Just to update on fuel consumption.
As you guys know, now I am using the gtec1 higher fuelling. Today, still about slightly above 1 bar left before empty tank, I have clocked 430 km.
I do a bit of high speed here and there but not all the time, just like how I normally drive. So, it is not burning a huge hole in my pocket, yet.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Postby pistole » Wed Jun 23, 2010 5:31 pm
- the car much more laju kah ?
- and that compressor outlet really shouldn't be a fixed metal pipe
welded to a flange.
pistole
IA Most Technically Helpful
Postby UlysseNuovo » Wed Jun 23, 2010 5:39 pm
pistole wrote:- the car much more laju kah ?
- have not really tested but it do feel like running out of breath.
- it is time for you to put in your snail :twisted: .
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby UlysseNuovo » Sat Dec 25, 2010 2:02 am
Just about a few weeks ago, my aircond blower was acting up. The time of the day you need it most, it was not blowing. I was still getting cold air when I open up the vent to take in outside air. Anyway, got it sorted out at Emech, the blower fuse fused. Change that and all is well. :mrgreen:
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby Redd » Sat Dec 25, 2010 8:55 am
UN, if it's one of the 3 fuses sitting just above the ABS pump in the engine bay, get chong to change them out to larger fuse holders. they will continue to melt and fuse until you do so. the original factory fuses are too small and cant cope with the amount of time we have our a/c on in msia climate. they will melt and fuse every couple months.
redd
Redd
Re: Project 300.
Postby gtfan » Sat Dec 25, 2010 12:58 pm
Yeah yeah stupid italian electronic....my kimchi ride 6 years also no such issue. Haha.
gtfan
Asst. Webmaster
Asst. Webmaster
Re: Project 300.
Postby UlysseNuovo » Sat Dec 25, 2010 5:28 pm
Eh, Coupe not bad what, '10' years only fuse fused. :mrgreen:
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby nahar » Mon Dec 27, 2010 9:18 am
Redd wrote:UN, if it's one of the 3 fuses sitting just above the ABS pump in the engine bay, get chong to change them out to larger fuse holders. they will continue to melt and fuse until you do so. the original factory fuses are too small and cant cope with the amount of time we have our a/c on in msia climate. they will melt and fuse every couple months.
redd
thats 50amp fuse...
nahar
Re: Project 300.
Postby Redd » Tue Dec 28, 2010 10:42 am
redd
thats 50amp fuse...
nope. it uses the same amp fuse as original, just a larger sized fuse. i think the smaller fuse just gets too hot and melts, and the larger fuse takes the heat better. whatever the reason, it seems to work.
redd
Redd
Re: Project 300.
Postby UlysseNuovo » Tue Jan 25, 2011 8:34 pm
Thanks Redd, that problem solved.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby UlysseNuovo » Wed Jan 26, 2011 3:05 am
Some months back after the dyno, I know that at the end of the rpm, I am running lean. So, I switch to Gtec2 higher fuelling from Gtec2 to hopefully solve the problem. But after that I am still running lean after about 4200 rpm.
At the back of my mind I was thinking it could be the fuel pump problem as I have to push the start button twice before Bella will start, maybe the one I gotten was fake or something that I bought from N1 (later found out it was not the pump problem). Went to Emech to switch it back to the standard pump and I don't have to push the start button twice to start Bella up. Yea! Problem solve, I should not be running that lean now.
So, went back to GT Auto to dyno. Arggghhhh! Still running lean. After some troubleshooting, found the cause. The fuel pump wiring, I should have change it earlier as recommended in our forum. :bangh: Use back the Walbro 255L fuel pump that I bought from N1 and using the Gtec2 higher fuelling, the problem of running too lean was better. But after running it for a few days, I notice that the fuel consumption was higher (of course la, higher fuelling mah).
Last month, I switch back to Gtec2 normal fuelling and only yesterday I went back to GT Auto to dyno. The result I posted on my facebook. I started to get lean earlier than the Gtec2 higher fuelling from about 5400 as Redd said. I was advise by Thomas from GT Auto, not to stay too long at 6000 plus rpm, which I do not think I will be doing so la. I love the nice AF ratio that Loki achieved for his R33.
So, now do I really have to go Live Map? :dunno:
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby UlysseNuovo » Wed Jan 26, 2011 3:12 am
Oh, my water temperature was acting up of late too. Notice it during our Fadil's Tribute Run. I was stuck in a traffic jam and my water temperature was hovering around 98 and even touch 100 and it was not under stress e.g. climbing hill.
After I dynoed, GT Auto change for me the coolant to Neo Synthetic Keep Cool. By the time I left, I was caught in the famous LDP jam. Temperature went back to just above 80 and almost touching 90. :mrgreen:
Total cost with dyno, RM230.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby pistole » Wed Jan 26, 2011 6:50 am
- adjustable FPR.
pistole
Re: Project 300.
Postby raitag » Wed Jan 26, 2011 7:41 am
can u set the adjustable FPR in accordance to the rpm?
ABA2800 WHY5594 WFH2088
WPV3156 WQG5988
raitag
Re: Project 300.
Postby pistole » Wed Jan 26, 2011 8:28 am
- takbleh.
- its across the entire rev range ...
pistole
Re: Project 300.
Postby raitag » Wed Jan 26, 2011 8:42 am
so, u could be running rich at lower rpm and just nice on the higher side la...
WPV3156 WQG5988
raitag
Re: Project 300.
Postby ognam » Wed Jan 26, 2011 9:09 am
Live mapping would probably be the ideal thing to do, but would be a hassle unless someone reputable can perform it here.
UN, that neo cool thing, is it a coolant option/replacement or additive ala water wetter?
Edit : re-read your post. You mention "changed", so must be a replacement.
Re: Project 300.
Postby pistole » Wed Jan 26, 2011 11:44 am
- scan your dyno chart.
- email to GrahamL.
- ask him to do a custom chip to address your lean-spot.
pistole
Re: Project 300.
Postby UlysseNuovo » Wed Jan 26, 2011 3:33 pm
Pistole,
I might just try the FPR first and see before looking into the other options. Thanks.
Ognam,
According to Thomas GT Auto is an additive. It cost RM60.
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby Kelv27 » Wed Jan 26, 2011 3:37 pm
Not sure if Graham does it anymore though.. I know Leighton (FC Performance) has done a few 'long distance' mapping with great success.. so try getting in touch with him. He sent me a revised chip the other day so I'm sure he'll be able to sort you out with one quickly too.
Kelv27
Re: Project 300.
Postby DeaDLocK » Wed Jan 26, 2011 4:13 pm
Yes, Leighton can do a custom map for you. He'll send you a base map (depending on what hardware you have), then you install the chip and dyno, scan the results and email to him. He then adjusts the map and sends you a new chip with the tuned results specific to your car.
I think Desin is the only one on here who has done this (for now :twisted:).
DeaDLocK
Re: Project 300.
Postby ognam » Wed Jan 26, 2011 4:39 pm
Pardon my sampai-mati-pun ignorance. So you're saying the only item that will be flying back and forth is just the chip? ECU stays at home? If that's the case, interesssting...
Re: Project 300.
Postby UlysseNuovo » Wed Jan 26, 2011 4:47 pm
ognam wrote:Pardon my sampai-mati-pun ignorance. So you're saying the only item that will be flying back and forth is just the chip? ECU stays at home? If that's the case, interesssting...
Yes. You still can drive with you original Lays Chip. :mrgreen:
But that tauke Desin always complaint. =))
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby gtfan » Wed Jan 26, 2011 5:08 pm
Aya, our coupe can do chip swap in 15 mins....last time at craven cafe....dunno how many times we swap in and out :mrgreen:
gtfan
Asst. Webmaster
Asst. Webmaster
Re: Project 300.
Postby UlysseNuovo » Wed Jan 26, 2011 5:24 pm
I will have to eat my words. I think I have yet to dyno with Gtec 2 higher fueling. :oops: Swap chip too often.
Tonight at Craven we will have a Chip swapping TT. :mrgreen:
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby gtfan » Wed Jan 26, 2011 5:27 pm
paging itu uncle harris....
gtfan
Asst. Webmaster
Asst. Webmaster
Re: Project 300.
Postby ognam » Wed Jan 26, 2011 6:12 pm
gtfan wrote:Aya, our coupe can do chip swap in 15 mins....last time at craven cafe....dunno how many times we swap in and out :mrgreen:
that's why.. if no need to courier the whole ecu, easy lor...
UlysseNuovo wrote:Tonight at Craven we will have a Chip swapping TT. :mrgreen:
boss.. got any extra chip ah?
Re: Project 300.
Postby Kelv27 » Wed Jan 26, 2011 6:16 pm
ognam, I've got a spare gtec2 you can borrow to test if you want :)
Kelv27
Re: Project 300.
Postby ognam » Wed Jan 26, 2011 6:49 pm
Kelv27 wrote:ognam, I've got a spare gtec2 you can borrow to test if you want :)
Thanks so much for the generous offer Kelv... but Gtec2 might be to kow for me. My car and myself are rather tame (and standard). Testing that chip could very well lead me to do other things. My aim isn't exactly in the 300s. :mrgreen:
gtfan wrote:paging itu uncle harris....
Cool. I have something to discuss with him.
Re: Project 300.
Postby gtfan » Wed Jan 26, 2011 8:39 pm
10pm tonight at craven....
Btw, ognam, you can use gtec 1 should be sufficient since you are still using standard turbo.
Gtec 2 normal fueling might not be suitable as the timing is slightly advance and not advisable for those who want to pump ron95
gtfan
Asst. Webmaster
Asst. Webmaster
Re: Project 300.
Postby ognam » Wed Jan 26, 2011 9:22 pm
gtfan wrote:10pm tonight at craven....
ron95? What is that? Haha... Let's continue discussion tonight. If my 10pm meeting finishes early. :duh:
Re: Project 300.
Postby UlysseNuovo » Wed Jan 26, 2011 9:49 pm
I will be late. Just finish dinner. :evil:
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby gtfan » Wed Jan 26, 2011 10:29 pm
kanasai...sitting alone here at craven.... :cuss-ing:
gtfan
Asst. Webmaster
Asst. Webmaster
Re: Project 300.
Postby Kelv27 » Thu Jan 27, 2011 12:05 am
No worries. Sorry, for some reason i thought you already had some work done to your car! :?
Kelv27
Re: Project 300.
Postby UlysseNuovo » Thu Jan 27, 2011 3:41 am
2 ECU removal and Chip replacement in less than 30 minutes at about 0210 hrs. :mrgreen:
Deng XiaoPing
UlysseNuovo
IA President
IA President
Re: Project 300.
Postby raitag » Thu Jan 27, 2011 7:36 am
i heard leighton is not cheap... and if anyone is going to do this, i suggest u dyno the car twice... once in the morning when it's cool and 2nd one at noon when it's hot... send both and hope he can tune to suit both conditions...
WPV3156 WQG5988
raitag
Re: Project 300.
Postby Kelv27 » Thu Jan 27, 2011 9:38 am
When he did mine in person, it was about 200 quid. Not sure if distance mapping would be cheaper...would imagine it to be but don't hold me to it :P
Yes, big difference in results with temperature. Basically, the more information you can provide him the more accurate he can map your parameters.
Kelv27
Re: Project 300.
Postby ognam » Thu Jan 27, 2011 11:19 am
UlysseNuovo wrote:2 ECU removal and Chip replacement in less than 30 minutes at about 0210 hrs. :mrgreen:
The virgin coupe took the longest time. And three people having a go at it. Haha. The Kraven Chip Swap Club :
UN, hope your fueling improves. ;)
raitag & kelv, sound advice. It might be pricier but would probably pay itself off in the long run, assuming the coupe performs well with optimum fuel efficiency after the mapping.
Re: Project 300.
Postby raitag » Thu Jan 27, 2011 11:37 am
first photo shows 2 guys at the passanger side... one tonggeng lagi... what the heck are u two doing ehh? :mrgreen:
WPV3156 WQG5988
raitag
Re: Project 300.
Postby Kelv27 » Thu Jan 27, 2011 11:42 am
Do you guys in IA get thattttt 'friendly'??? :shock:
Kelv27
PreviousNext
Users browsing this forum: No registered users and 4 guests
