raitag wrote:thermostat issue i think...
hero wrote:Cylinder head gasket?
zainframe wrote:hero wrote:Cylinder head gasket?
How could it be the gasket? care to elaborate?
thanks
ognam wrote:Had this issue coming down Genting last Sunday. Temp went up one notch only. Even less than a quarter. As a result I didn't floor it. Went back to the normal 90 as soon as I hit KL. In my case, don't think it's thermostat
Redd wrote:ognam wrote:Had this issue coming down Genting last Sunday. Temp went up one notch only. Even less than a quarter. As a result I didn't floor it. Went back to the normal 90 as soon as I hit KL. In my case, don't think it's thermostat
happens all the time. when ur driving down genting ur seldom on hard throttle (more brakes than throttle) and the cool mountain air plus good airflow at speed keep your engine much cooler than usual. u shd see normal engine temps once u hit karak.
zain - ur a/c and stat issue could be related. possibility that ur fans are not turning on due to the coolant temp being low (stat stuck open), and thus ur a/c isn't cooling down as quickly. but afaik, the fans should come on as long as the a/c is on, regardless of coolant temp. check ur fan relays.
redd
