central lock button
central lock button
Postby puchongbala » Tue May 01, 2012 10:07 pm
Having this issue intermittently.
Sometimes able to lock.
Sometimes it just doesn't work at all (nothing despite repeated pressings) or it just locks & the unlocks again.
Any ideas on wot could be the problem & possible solutions?
TQ in advance.
puchongbala
Re: central lock button
Postby Kelv27 » Tue May 01, 2012 11:04 pm
A problem that commonly plagues the coupe but one that is difficult to pinpoint. I would start by making sure your door latches are well lubricated. When it's abit 'sticky', the central locking would reject the command of locking...similar to when a door is not shut properly.
Kelv27
Postby joe_yong » Wed May 02, 2012 12:27 am
for me, i suspect more to the wiring condition. i normally faced this when i have been running hot, hard runs, traffic jams...
joe_yong
Postby invisibleghost » Wed May 02, 2012 8:54 am
piece of advice. live with it
cheers
Food
Car
To accomplish great things, we must not only act, but also dream;
not only plan, but also believe.
~Anatole France~
invisibleghost
Postby ognam » Wed May 02, 2012 8:59 am
Be grateful you have central locking to begin with.
Postby farmer » Wed May 02, 2012 9:02 am
If both of your doors are shut properly when this happened, check the spring loaded switch in your boot, left side. Most time it is loose after repeated use and needs minor adjustments.
farmer
Postby stereotypical » Wed May 02, 2012 9:43 am
try taking out the fuses/relays underneath the drivers side near the hood release for few seconds then put them back in, it resets the central locking, worked for mine.
stereotypical
Postby jamslau » Thu Sep 06, 2012 11:50 pm
There is a open/close sensor inside the door lock mechanism. When door is closed, the sensor wire (white color)short to (-), maybe you need to clean/service this, because sometimes door is closed but sensor says opened, so central lock unlocks again.
jamslau
Postby raitag » Fri Sep 07, 2012 9:04 am
need to remove lock?
ABA2800 WHY5594 WFH2088
WPV3156 WQG5988
raitag
Postby gtfan » Fri Sep 07, 2012 9:53 am
I am still manually locking my door for both passenger and me :? since my central locking went nuts.
Haven't got the time to troubleshoot and most mechanic are lazy to troubleshoot. They just says, change #-o
Anyway, i already have a pair of central locking sets i bought new from Torino and yet to install. And this is my seconds set. And still the problem comes after a few years.
Perhaps it could be contacts issue. Have to dig coupe manual diagram and see how to remove the lock.
gtfan
Asst. Webmaster
Asst. Webmaster
Postby Kelv27 » Fri Sep 07, 2012 11:00 am
Its not the lock itself. Its the solenoid that actuates the locks.
Kelv27
Postby studmuffin » Sat Sep 08, 2012 11:21 am
emech fixed it for me b4 i sold the coupe
a bad day of fishing beats a good day at work
studmuffin
Postby studmuffin » Sat Sep 08, 2012 11:25 am
i think the solenoid was replaced
studmuffin
Postby Maniac » Sat Sep 08, 2012 11:35 pm
Newbie question. When u guys mention about buying stuff from Torino, it is Torino Shah Alam and not Italy right?
Maniac
Postby raitag » Sun Sep 09, 2012 9:05 am
Torino Ulu Kelang...
WPV3156 WQG5988
raitag
Postby puchongbala » Wed Sep 12, 2012 12:14 pm
studmuffin wrote:i think the solenoid was replaced
How much was the repair job?
puchongbala
Postby studmuffin » Wed Sep 12, 2012 4:24 pm
if i,m not mistaken around 200+
studmuffin
Postby DrItalia » Mon Oct 22, 2012 4:28 pm
Hi guys,
My central lock button started acting funny recently. Sometimes works sometimes doesnt..... So, got a brake switch lock fitted at KK Lau in Damansara Ara. Now dont need to touch the button anymore. Press brake and doors lock. Switch off ignition and doors unlock. Cost me RM180 and glad i din have to touch the centre panel etc and all works fine now \:D/
Could be a solution for you guys havin d same problem too....
DrItalia
Postby gtfan » Tue Oct 23, 2012 10:15 am
DrItalia wrote:Hi guys,
Cool. Great tips there.
gtfan
Asst. Webmaster
Asst. Webmaster
Postby puchongbala » Thu Oct 25, 2012 2:41 pm
That's great.
care to post KK Lau's address & tel number?
TQVM
puchongbala
Postby DrItalia » Fri Oct 26, 2012 4:50 pm
Here u go! Have fun! :)
K.K.Lau Audio Specialist Sdn. Bhd.
No: 1 Block I, Taipan Damansara II, Jalan PJU 1A/1, Ara Damansara, 47301, P.J, Malaysia
Tel: 603.7843 6890 Fax: 603.7843 6892
GPS Coordination:
Latitude: N0307'02   Longitude: E10134'46
DrItalia
Users browsing this forum: No registered users and 2 guests
