Coupe Wont Start!! HELP
Postby edly » Sun Sep 16, 2012 3:03 pm
Hey guys.
anyone knows how to troubleshoot this?
The story was,.....
last nite bella's aircond got problem with wiring. This aircond wiring problem is a norm to my bella.
normally what i'll do is i'll first remove the battery terminal and work on the wiring. after done with it i'll put back on the battery terminal and will turn the ignition on(1 click turn) w/out starting the engine
and try to find out whether the aircond blower will turn on. So, i've manage to troubleshoot the wiring problem. Then started the engine and it went dead. tried to crank it back but there's nothing on even the indication light on the dash in not on.
maybe the battery terminal wasn't tight enough for the current to flow. Then i tighten the loose battery terminal. Then when i turned the ignition on the 'CODE' indication was on and stays on. started the engine and it seems that the engine cant catch the fuel.... this code reading from key issue happened to me once and towed the car to ah Jins and he troubleshot this problem like a boss! ..ahaha... and i recall that he didnt to anything fancy mechanic work on it .. just a simple touch here and there, and the car started.
so now, i dont want to spend money on towing bella to the workshop and i've only 1 key,.. the everyday key to turn the engine on,..no blue ke,..red key,...rainbow key or whatsoever,..
Please help on how to troubleshoot this problem. :bangh:
Thanks folks
edly
Re: Coupe Wont Start!! HELP
Postby edly » Sun Sep 16, 2012 3:31 pm
ok nevermind... problem SOLVED! :)
edly
Postby maxcobmara » Sun Sep 16, 2012 4:16 pm
Mind sharing what the issue was for future reference
MaxCobMara :
Yang boleh tahan tu tak pe, yang tak boleh tahan yang takut tu
maxcobmara
IA Committee
IA Committee
Postby jamslau » Sun Sep 16, 2012 5:04 pm
Check all the fuses.
jamslau
Postby edly » Mon Sep 17, 2012 3:11 am
i took out both battery terminal ... leave it for half hour or so,... then tighten both back .... :mrgreen: ..ahaha .. silly me! :P
edly
Postby ongka66 » Wed Oct 03, 2012 10:24 pm
U really lucky lol!
ongka66
