Cheap fix for sagging front springs
Postby jamslau » Mon Oct 01, 2012 7:47 pm
Hi people,
My coupe's springs are old & sagging lower, so the bumper scrapes ramps & my driveway. So I tried a cheap solution today. Spring buffers, RM38/pr. Added about 1" height, quick test showed no problems, similar characteristics to old springs.( don't expect springs to become lively again though)
DIY difficulty level 3/10
http://www.facebook.com/photo.php?fbid= ... =1&theater
http://www.facebook.com/photo.php?fbid= ... permPage=1
jamslau
Re: Cheap fix for sagging front springs
Postby Raziack » Thu Oct 04, 2012 12:36 pm
good alternative..
Eat Dhall N Fart Well
Raziack
Postby Maniac » Tue Oct 09, 2012 2:52 pm
Are the buffers only for the front or can they be used for all four sides?
Maniac
Postby jamslau » Tue Oct 09, 2012 11:23 pm
I only installed on my front springs to raise them. But the buffers come in many sizes,
Sizes here: http://www.facebook.com/photo.php?fbid= ... =1&theater
You must jack up & measure the rear springs diameter & clearance & thickness to choose the right one. Bear in mind, it will raise the rear 1-1.5 inches too.
jamslau
Postby Maniac » Fri Oct 12, 2012 9:23 am
Can I just buy it from the shop and ask them to fix? The whole jacking up and measuring is gonna cause me angst.
Maniac
Postby jamslau » Sun Oct 14, 2012 1:43 am
Yes they have ppl to install for a fee, it should take 2 mins per piece.
jamslau
Postby Maniac » Sun Oct 14, 2012 7:16 pm
Thanks for the info. So which shop do I go to for all this? Who do I contact?
Maniac
Postby Raziack » Sun Oct 14, 2012 8:30 pm
I got see this in glory.
Raziack
Postby Maniac » Tue Oct 16, 2012 12:45 pm
But glory does not fix the buffers. I would like to know where I can get help with the installation as well as I don't know the measurements for the buffers either.
Maniac
Postby jamslau » Tue Oct 16, 2012 4:24 pm
Go to the nearest brothers shop, they install too. http://www.brothers.com.my/outlets.php
jamslau
Postby jamslau » Tue Nov 27, 2012 2:15 pm
I've installed buffers for my rear springs, size is C, coil inner diameter 1.5" , outer 2", thickness 0.25". I'm using it to raise the rear a bit to clear the side exhaust pipes.
(front springs replaced with new original, buffers removed because the new springs are higher now. Rear still old springs)
jamslau
