Cheap fix for sagging front springs
Dedicated section just for the Fiat coupe owners!
Postby jamslau » Mon Oct 01, 2012 7:47 pm
Hi people,
My coupe's springs are old & sagging lower, so the bumper scrapes ramps & my driveway. So I tried a cheap solution today. Spring buffers, RM38/pr. Added about 1" height, quick test showed no problems, similar characteristics to old springs.( don't expect springs to become lively again though)
DIY difficulty level 3/10
http://www.facebook.com/photo.php?fbid= ... =1&theater
http://www.facebook.com/photo.php?fbid= ... permPage=1
jamslau
Re: Cheap fix for sagging front springs
Postby Raziack » Thu Oct 04, 2012 12:36 pm
good alternative..
Eat Dhall N Fart Well
Raziack
Postby Maniac » Tue Oct 09, 2012 2:52 pm
Are the buffers only for the front or can they be used for all four sides?
Maniac
Postby jamslau » Tue Oct 09, 2012 11:23 pm
I only installed on my front springs to raise them. But the buffers come in many sizes,
Sizes here: http://www.facebook.com/photo.php?fbid= ... =1&theater
You must jack up & measure the rear springs diameter & clearance & thickness to choose the right one. Bear in mind, it will raise the rear 1-1.5 inches too.
jamslau
Postby Maniac » Fri Oct 12, 2012 9:23 am
Can I just buy it from the shop and ask them to fix? The whole jacking up and measuring is gonna cause me angst.
Maniac
Postby jamslau » Sun Oct 14, 2012 1:43 am
Yes they have ppl to install for a fee, it should take 2 mins per piece.
jamslau
Postby Maniac » Sun Oct 14, 2012 7:16 pm
Thanks for the info. So which shop do I go to for all this? Who do I contact?
Maniac
Postby Raziack » Sun Oct 14, 2012 8:30 pm
I got see this in glory.
Raziack
Postby Maniac » Tue Oct 16, 2012 12:45 pm
But glory does not fix the buffers. I would like to know where I can get help with the installation as well as I don't know the measurements for the buffers either.
Maniac
Postby jamslau » Tue Oct 16, 2012 4:24 pm
Go to the nearest brothers shop, they install too. http://www.brothers.com.my/outlets.php
jamslau
Postby jamslau » Tue Nov 27, 2012 2:15 pm
I've installed buffers for my rear springs, size is C, coil inner diameter 1.5" , outer 2", thickness 0.25". I'm using it to raise the rear a bit to clear the side exhaust pipes.
(front springs replaced with new original, buffers removed because the new springs are higher now. Rear still old springs)
jamslau
Return to Fiat Coupe
Users browsing this forum: No registered users and 2 guests
