Boosting and Vibration
Dedicated section just for the Fiat coupe owners!
Postby Fastfast » Mon Dec 10, 2012 1:33 pm
Hi guys, following my issue on hoses which I have fixed, now boost works. However I'm experiencing vibrations whilst boosting or revving at higher rpms. It happens on lower gears when speed is low. Whilst boosting at say 20kph or second/first gear, te engine bay vibrates sometimes seems like whole front end. Whilst boosting at say 60 onwards not so prominent or none at all.
Was wondering whether its too much boost for low speed or mounting cannot cope? It any other issues...
Thanks
Fastfast
Re: Boosting and Vibration
Postby Kelv27 » Mon Dec 10, 2012 4:55 pm
Really depends on what you mean by vibration. Do you mean that the engine is hesitating/jerking/misfiring when on boost? If so, could be a few things. I would start with the MAF, followed by the coilpacks.
Kelv27
Postby Fastfast » Mon Dec 10, 2012 9:50 pm
Yes, its like hesitating rather jerking or misfiring. Its like the transfer of power is not full to the wheels. When i can, i show you.... maybe during a year end Ulu Yam run? Time to do one maybe? :)
Fastfast
Postby Kelv27 » Mon Dec 10, 2012 10:21 pm
You want to run at ulu yam like that?? Kaboooom :mrgreen:
You're so nearby, just call me anytime la.
Kelv27
Postby Fastfast » Mon Dec 10, 2012 11:14 pm
Won't kaboom one. Hold back throttle during start of run and get cursed from ppl at the back only.... hahahah....
Fastfast
Postby raitag » Tue Dec 11, 2012 9:19 am
could be clutch?
ABA2800 WHY5594 WFH2088
WPV3156 WQG5988
raitag
Ex-Mafia Boss
Ex-Mafia Boss
Postby Fastfast » Tue Dec 11, 2012 11:27 am
I guess it's possible but would it happen to only first 2 gears? But it only happens when I push. Normal driving like say revving up to 3.5 rpm before changing don't see this occurring or at least less le depending on the foot.
Fastfast
Postby bravosx » Tue Dec 11, 2012 12:41 pm
raitag wrote:could be clutch?
Could be drive shaft too.
For Sale:-
Genuine CHIVAS REGAL SCOTCH WHISKY
viewtopic.php?f=23&t=29906
For Sale:-
Fiat Bravo 1.6SX 1997 model. Lots of extras comes with the car.
bravosx
Postby Fastfast » Tue Dec 11, 2012 1:24 pm
Wah that one expensive aint it?
Fastfast
Postby desin » Tue Dec 11, 2012 4:43 pm
if rpm hit 6800rpm, it will auto-cut... and car will be jerky during that period.
desin
IA Northern Rep
IA Northern Rep
Postby Fastfast » Tue Dec 11, 2012 8:16 pm
Don't really go to that level so would not know whether cut off or not...
Fastfast
Postby ognam » Tue Dec 11, 2012 10:25 pm
Fastfast wrote:I guess it's possible but would it happen to only first 2 gears? But it only happens when I push. Normal driving like say revving up to 3.5 rpm before changing don't see this occurring or at least less le depending on the foot.
Clutch usually slips (if its slipping) in those gears. Does your rpm shoot up but your car is going nowhere?
Eh. Go visit your neighbor la senang cerita. Haha.
ognam
Postby Fastfast » Tue Dec 11, 2012 10:57 pm
hahaha... ok la i think its about time i actually visit my neighbour le... can't seem to define it properly here. I'll contact him.
Fastfast
Postby Pangmy3 » Thu Dec 13, 2012 1:58 pm
or maybe ur drive shaft inter head kong,,,better go to shop n check..bro
Pangmy3
Postby Fastfast » Fri Dec 14, 2012 10:10 am
Ok ok thanks... Will get EMech to look at it when possible. Thanks for all the feedback. :)
Fastfast
Postby Fastfast » Mon Dec 24, 2012 9:45 pm
Following up from this, I think may have found partial answer to this. The turbo hose which I replace is loose or at least dunno why I keep needing to tighten it every once a while. When I tighten, the vibration is less and the pick up smoother. Only when it's loose it gets noticeable. EMech tested clutch and said no problem. However not sure if it could also be caused by manifold which could have cracked. Will check next round.
Is there anyway to make the boost hose tighter and not get loose once a while? Think when boost too much it gets loose. Or maybe the clip I use is not thick enough to withstand the pressure.
Merry Christmas!!
Fastfast
Postby ognam » Tue Dec 25, 2012 2:51 am
If your hose keeps loosening up, then perhaps it's not up to the job.
Go to your local parts shop and get a new one. Ask for the most expensive and thickest one they have. They're usually around RM6-RM12.
Or go to a kakimotor outlet and grab some t-bolt clamps.
And since you will be in that area of the engine, also check condition of the big ass hose after the throttle body. Those are prone to cracking and I've known some people who never check and live with a boost leak. That particular piece is readily available in silicone. Not a Fiat Coupe specific part unlike the S-shaped hose.
All the best!
ognam
Postby Kelv27 » Tue Dec 25, 2012 5:56 pm
Which hose is this that keeps getting loose btw? Yeah as Ognam mentioned, a new hose clip would sort it out.
As for the hose that meets the throttle body, there's actually a slight bend to it so that the big plastic intake pipe doesn't get too close to the cam cover.
Kelv27
Postby Fastfast » Tue Dec 25, 2012 10:05 pm
Kelv, its the same hose which i was looking for. The S-curve boost hose.
Ognam, yes its probably the job and material. Job i.e. me doing a lousy job :p material i.e. the clip i used was not thick enough to hold it in place. Now replaced better, but still got little vibration in gear 1 and 2, something which was already there prior... which i think could be attributable to maybe a cracked exhaust nearest to the engine. Cracked once but welded it ;D
Fastfast
Postby Fastfast » Tue Dec 25, 2012 10:07 pm
Oh and where is the hose near the throttle body. Don't even know where is the throttle body. hahaha...
Fastfast
Postby Kelv27 » Wed Dec 26, 2012 11:05 am
See label 'Throttle Position Sensor'. That sensor is attached to the Throttle Body a.k.a butterfly valve.
Kelv27
Postby Fastfast » Wed Dec 26, 2012 1:05 pm
Oh wow. Thanks! :) so according to ognam, the hose he mentioned is the straight one before the s curve turbo hose? Will see how I can check that out. Thanks
Fastfast
Postby ognam » Wed Dec 26, 2012 1:14 pm
Fastfast wrote:Oh wow. Thanks! :) so according to ognam, the hose he mentioned is the straight one before the s curve turbo hose? Will see how I can check that out. Thanks
Yeah the big kahuna. The fiat part is ever so slightly curved as Kelv mentioned, but I see a few cars using a generic straight hose with no issues. In fact, I was using a straight silicone hose before I got my Samco kit.
ognam
Postby Fastfast » Wed Dec 26, 2012 7:30 pm
Ah ok ok... Will picit picit and see if got cracks. Thanks
Fastfast
Postby Fastfast » Sun Dec 30, 2012 1:31 am
Yo guys, dunno whether this is normal.... So I've re tighten the hose clip. Think it's a stronger hold. At te start its ok. After couple of days the vibration starts again... Sienzzz... Then the strange thing is, it's less when there's 2 person in the car ie passenger front and driver. Strange strange. I already dumbfounded already or just dumb le.... Asked EMech not clutch, hose change, clip wider. Dunno what else since its an on and off thing.
Fastfast
Postby bravosx » Sun Dec 30, 2012 5:45 am
Rims got bengkok? Drivevshaft ok?
For Sale:-
For Sale:-
bravosx
Postby Fastfast » Sun Dec 30, 2012 9:07 pm
Dunno whether drive shaft ok a not. EMech quite busy now so no time entertain me. But if drive shaft koyak it should be permanent vibration no? Not just some gears... Could it be tayar botak has effect?
Fastfast
Postby bravosx » Sun Dec 30, 2012 9:15 pm
If tyre surface uneven then maybe yes. If tyre surface uneven you could be looking at rim bengkok too I guess.
For Sale:-
For Sale:-
bravosx
Postby Kelv27 » Sun Dec 30, 2012 9:55 pm
Could be simple things like wheels out of balance..
Kelv27
Postby Fastfast » Mon Dec 31, 2012 1:58 am
ok. let me go change the front tyres and see whether its the same. Anyway, will be going to SS14 shop to change. Can't remember the name but few doors down to Fawaz... anyway just want to ask, when they do alignment do you let them adjust or insert a camber. They always ask me one....
Fastfast
Postby bravosx » Mon Dec 31, 2012 9:12 am
Camber nuts are shite.....it doesn't do jack shit. Better to get someone who knows our cars well to do alignment, balancing or even camber adjusting like CD in OKR or the other guy a few blocks away. Being NY Eve, I reckon everyone is rushing to get things done.
For Sale:-
For Sale:-
bravosx
Postby Fastfast » Sun Jan 06, 2013 1:45 am
Hi guys happy new year!!
Got it all done... Fingers crossed no more issue with this. Was due to the joint of the drive shaft to the body (not sure what that is called). The cover tore and probably some sand went in. But mainly the vibration was due to the drive shaft being loose to the joint. And some rubber bearing old already and brittle giving space for rattling and vibration. Now can feel the power from the pedal.
Anyway thanks for all the advice.. Next... Boost meter installation. Haha still not done yet. :D
Fastfast
Postby Pangmy3 » Sun Jan 06, 2013 2:09 pm
drive shaft joint to the body???to gear box or to wheel???
Pangmy3
Postby Fastfast » Sun Jan 06, 2013 8:24 pm
To the wheel.
Fastfast
Postby Kelv27 » Sun Jan 06, 2013 8:38 pm
It's called the outer Constant Velocity Joint (CV Joint).
Kelv27
Postby Fastfast » Tue Jan 08, 2013 1:47 pm
Haha thanks kelv! :D
Fastfast
Return to Fiat Coupe
